Weird connection problem
(Topic created: 09-20-2021 12:55 PM)
RangerDanger
Galaxy S21
Hey all,
I wanted to see if anyone else has had a similar connection problem to mine. Sometimes my phone will show I have cellular service but I am unable to send or receive any text messages or phone calls until I toggle airplane mode. It does not seem to be location based either, the other day I left my house and headed into the city, about half way there I thought it was weird no one had responded to my text so I toggled airplane mode and then I got flooded with messages I had not received yet. I've tried everything, even a factory reset and it still happens from time to time. It's starting to make me go mad
SamsungQue
Galaxy S21
I can understand how frustrating this issue can be. I would recommend that you try swapping the sim card out. I would also recommend reaching out to your service provider
userxIrdCGGxvS
Galaxy S21
somtime everything is wipe from my phone
RangerDanger
Galaxy S21
Ok....
SamsungQue
Galaxy S21
TheGalaxy
Neutron Star
Galaxy S21
Settings
Apps
Show system app
Search for network
Clear data for all related apps
Galaxy S21
Verizon has been having outages and problems with this... the carrier reprograms something on their end
