Wireless Charger won't charge and shows a flashing orange light
(Topic created: 03-12-2021 06:34 AM)
userQSTVhKXkjF
Galaxy S21
Just purchased a EP-P1300 wireless charger for my brand new S21+.  It worked the first time i used it but since then it wont charge and shows a flashing orange light. It shows red, green and orange when powering up. Any ideas
StephanieNikki
Black Hole
Galaxy S21
Thank you so much for reaching out. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link:https://www.samsung.com/levant/info/contactus/
StephanieNikki
Black Hole
Galaxy S21
user5OlJ5uL2im
Galaxy S21
Exact same thing with mine, but I have the US model, it seems like these fail very frequently!
