still wishing battery was better s21 ultra
(Topic created on: 2/23/21 1:39 PM)
invis52
Nebula
Galaxy S21
I have an s21 ultra and the batter just doesn't feel very premium at 71% after bout 2hours 12 minutes SOT 45 minutes YT 1 hour messages the rest just through home page and stuff whem will the so called 10 hz ever come bec i only am on 720p 60z but maybe i just expect to much from this phone it trys it's best. Still great 7-8 hour battery life
invis52
Nebula
Galaxy S21
all my apps are in deep sleeping adaptive battery Bixby routines adaptive power save auto restart every other day
invis52
Nebula
Galaxy S21
kk i will look
CaryS21Ultra
Galaxy S21
question? I've been told not to use Bixby on my note 9. Has the Bixby experience improved since then?
Mari_K
Samsung Care Ambassador
Galaxy S21
Bixby has definitely improved since then, and if you haven't been using another service in Bixby's place, give it a try. I've been using the Google assistant for so long, I'm just used to it.. so I haven't given Bixby another try yet.
*if I have helped you, please LIKE this post. If I have helped solve your problem, please mark this as a SOLUTION. Hope you have a great day!
invis52
Nebula
Galaxy S21
i don't use it as search engine but she can help you change your settings and routins helpful
CaryS21Ultra
Galaxy S21
Thank you. You must hear "I've been using Google for so long". I'll give Bixby another try.
Mari_K
Galaxy S21
you may think all of your apps are in a deep sleep, but obviously there is something that's using up your battery. if you check in device care and click on the battery graph it will tell you exactly which apps are using up your battery
userrl1pkmY3Pp
Galaxy S21
thanks. I'll check
