Battery drain
(Topic created: 06-11-2025 05:31 AM)
Galaxy S22
Do we know of any one ui7 battery drain patch coming out or is Samsung just going to ignore it and continue to work on one ui8 .
Samsung_Moderator
Galaxy S22
Hello Intŕù5ìv3, Welcome and thank you for being part of the Community! We understand the disappointment of decreased battery life after an update.
Check out this link with best practices after an update: https://us.community.samsung.com/t5/Tips-Tricks/Best-Practices-After-an-Update/ba-p/3200871
If you are experiencing an exorbitant amount battery drain, repairs would be recommended. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
realaud
Honored Contributor
Galaxy S22
Optimize YouTube.  That was found to be a major culprit in battery drain.  Seems it's always running in the background (even if you don't use the app). Check your battery usage and see what your top 3 or 4 battery chewers are and put them to sleep or deep sleep or restricted in optimization.
Please mark any response that helped you as your solution.
Samsung_Moderator
Galaxy S22
