Battery icon in top right corner is too small now with latest update
(Topic created: 02-03-2026 07:45 AM)
orchestra1
Galaxy S22
The latest updated made my battery icon in the top right corner so small I can hardly read it. (the one that shows the percentage of where my battery is.)
Why would you do that?  Not everyone has 20/20 vision.  My phone died yesterday because I could read the stupid battery percentage.
Please change it back.  I can't see it at all!!!!
Pianodude58
Honored Contributor
Galaxy S22
It's not going to change back to what it was, however I heard it will be customizable in One UI 8.5 Stable Release.
orchestra1
Galaxy S22
Any idea when this will happen?  It's driving me nuts!!😜
MrGhoul
Neutron Star
Galaxy S22
Yes, the icon is terrible and hard to see.
You can download a battery widget of your choice from the Galaxy store / Google play.
Robin621k
Honored Contributor
Galaxy S22
In Ui 8.5 you will be able to turn off the pill and just have the percentage. When will it come to the S22 series, my guess is either March or April.
Until then I suggest you use the battery widget.
nullandvoid
Comet
Galaxy S22
Create a routine to let you know when the battery goes below a certain percent. That way you never even have to look at the battery pill - just charge when the notification appears.
