- Mute
08-24-2022 04:33 PM in
Galaxy S22The thenar is the fatty mass at the radial of the thumb. My thenar is extra fatty and the rest of my hand is corpse-like. So, when I hold my phone, the corpulent nature causes it to envelop the left side of the phone. It flows over far enough that it will rest over the edge and I have an S22 Ultra, so there are hundred of button to push along that edge.
Is there a way to turn down the sensitivty of the edges. Better yet, disable it? Should I try taping it down.
Even with my phobe case, it still happens..
Thank you
Solved! Go to Solution.
- Mute
08-26-2022 01:51 PM in
Galaxy S22Thank you for reaching out. I understand your frustration with Edge sensitivity. The Edge Screens on your Galaxy phone automatically disregard some touches to prevent unwanted interactions while you're holding the phone. However, you can adjust which areas are disregarded using the EdgeTouch app, available on the Galaxy Store. Once you install the app use this link to help you: https://www.samsung.com/us/support/troubleshooting/TSG01109061/
- Mute
- Mute
08-27-2022 03:01 PM in
Galaxy S22
