S22 series of phones Battery Drain
(Topic created: 03-01-2022 06:30 PM)
Guinn5
Galaxy S22
The Galaxy s22 drops battery  very quickly  within minutes. Like it goes from 85 to 79 extremely quick. I know the capacity  is low but the chip is supposed  to be optimized can Samsung  please push out an update. I only had this phone for 4 days now.
JUMP TO SOLUTION
Blk_Superman73
Galaxy S22
The battery life sucks for S22 Ultra
Zaedus
Galaxy S22
I've had nothing but good battery life, and everyday I've noticed it getting better, and improving. Especially after today I've noticed my battery is lasting longer than the first day.
S22Ultra
Galaxy S22
Is it just me or did any of your observe faster battery drain in your S22 ultra? When you charge to 100%, the battery drains quickly to 90% in a flick of a second. Samsung should fix this issue.
krayzie15
Supernova
Galaxy S22
My s21 was like that it got a ton better
Mrsc313
Galaxy S22
Mine too.
SpaDeSanDlove
Galaxy S22
Same here!
userGSu4FT0LfI
Galaxy S22
I have the same issue with the compact s22. Battery drains really quickly with light use. Samsung please fix the quick battery drain issue for these flagship phones.
userGSu4FT0LfI
Galaxy S22
I have the same issue with the compact s22. Battery drains even with light usage. Samsung please send a system update to fix the battery drain issue.
Samsung_Moderator
Galaxy S22
Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Note: The battery adaptive feature on S22 phone, may cause the battery to drain a little faster at first until the phone adapts to your usage, and learns how you're operating, the charge will be stored and used in different manners based on how you use your phone. This sometimes can take a few weeks for it to learn the habits and customize itself to make sure you have the best performance and lasting battery.
Optimize Apps:https://www.samsung.com/us/support/galaxy-battery/optimization/
If you're receiving an overheating message check out the following link:
https://www.samsung.com/us/support/answer/ANS00076952/
If you've tried troubleshooting above, when it comes to problems overheating or exorbitant drain to the battery, repairs would be recommended. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you.
uservGLKszwtoy
Galaxy S22
I purchased two S22 Ultra's and after all of the information that was published about the larger battery for the phone, it gave me the impression it should last for 10-12 hours w/o needing charged.  On average, I'm getting 8+ hrs with little usage during the day.  Now there are even blogs and videos that are showing the phone isn't lasting as long as the iPhone 13 Pro.  It seems that Samsung should be giving us better tech given the amount of money the consumers are having to pay for these devices!
