- Mute
03-01-2022
06:30 PM
(Last edited
02-02-2023
04:37 PM
by
SamsungJoJo
) in
The Galaxy s22 drops battery very quickly within minutes. Like it goes from 85 to 79 extremely quick. I know the capacity is low but the chip is supposed to be optimized can Samsung please push out an update. I only had this phone for 4 days now.
Solved! Go to Solution.
- Mute
07:09 AM
(Last edited
10-05-2022
04:48 PM
by
SamsungRei
) in
Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Note: The battery adaptive feature on S22 phone, may cause the battery to drain a little faster at first until the phone adapts to your usage, and learns how you're operating, the charge will be stored and used in different manners based on how you use your phone. This sometimes can take a few weeks for it to learn the habits and customize itself to make sure you have the best performance and lasting battery.
Optimize Apps:https://www.samsung.com/us/support/galaxy-battery/optimization/
If you're receiving an overheating message check out the following link:
https://www.samsung.com/us/support/answer/ANS00076952/
If you've tried troubleshooting above, when it comes to problems overheating or exorbitant drain to the battery, repairs would be recommended. You can use the following link to find a list of service centers in the U.S. that can do the repair: http://www.samsung.com/us/support/service/location or by contacting customer support at 1-800-726-7864.
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
- Mute
03-02-2022 02:36 PM in
Galaxy S22I am sorry to hear of the S22 battery life not lasting for long, and can understand the frustration. When you get a brand new phone, the battery will take time to adjust to your usage and optimize its performance, so waiting and continuing to use the device will result in a better battery life over time, usually a few days to a week after. It can also be dependent on what app(s) you are running on the phone. Some things that can help with Battery optimization in addition are the following:
Optimize Apps:http://www.samsung.com/us/support/troubleshooting/TSG01001388/
Power Saving Mode & Battery Tips: https://www.samsung.com/us/support/answer/ANS00079037/
If after waiting for the battery to adjust to your usage and trying the above do not work, there is always the option for repair, covered under the 1-year warranty. You may look into walk-in service repair options at your local uBreakiFix: https://www.ubreakifix.com/locations
Samsung also offers ship-in repair options. Typically if uBreakiFix cannot fix an issue, the next step would be the ship-in repair. To look into ship-in options, you can private message us here with the full model code and IMEI number: https://bit.ly/3pE8Pkc
- Mute
02-27-2022 05:45 PM in
Galaxy S22.
I charged the 22 Ultra to 85%
Next , I fired up Samsung TV Plus and put it to full screen and placed it on a shelf in the computer room, and wife and I jumped on the motorcycle and off for a ride the rest of the day.
Did I mention the S22 was charged to only 85% , NOT 100% ??
Okay... check the screenshot
Keep in mind I first fired up the 22 on Thur, so battery is still learning usage ... I say, another week and it should be settled in
In case the screenshot is non readable:
SOT : 11 hrs 12 mins
- Mute
03-04-2022 05:06 AM in
Galaxy S22There is a protect battery setting ( under more battery settings), that stops charging at 85%. You probably just need to go in and turn off that setting.
- Mute
03-04-2022 05:34 AM in
Galaxy S22I have that setting turned On ... on purpose ...
- Mute
02-23-2022 01:22 PM in
Galaxy S22- Mark as New
- Mute
02-23-2022 01:49 PM in
- Mute
02-23-2022 02:02 PM in
- Mute
02-23-2022 02:04 PM in
- Mute
Galaxy S22
