Side button no longer works for power
(Topic created: 05-13-2025 10:05 AM)
usercREmNcuNbq
Galaxy S22
After latest update I can no longer use the side button to restart my phone!
nick710
Cosmic Ray
Galaxy S22
You can reset the side button back up to do it again in settings just search for side button. Alternatively you can just swipe down from the top and the option to restart or shutdown will be in the top right corner shown as a power symbol
nick710
Cosmic Ray
Galaxy S22
usercREmNcuNbq
Galaxy S22
Thank you!!!
nick710
Cosmic Ray
Galaxy S22
Np 🙂
usercREmNcuNbq
Galaxy S22
Why didn't I think of that....duh!!!
Mysticalray
Galaxy S22
Advanced features, side button/volume, change long press to power menu. I noticed it yesterday.
userMvOBwrkkox
Galaxy S22
When I hold the side button down, there's a button at the bottom that says side button settings...
