Wired dex bluetooth audio issue
(Topic created: 12-11-2025 08:28 PM)
FrankS1
Galaxy S22
When making a bluetooth connection before or after a wired dex connection is started to my stereo paired A1 2nd Gens the sound is not in the foreground as it should be but rather in the background. The bluetooth system app cache is greyed out and cannot be cleared. There are no settings in Sound Assistant to deal with this or in the general sound settings or dex settings. The problem began with one ui8 android 16 and appeared to be resolved in the November update but has returned. Can an update be rolled out to fix this asap? The wired connection is via a dex pad. Have other users had the same issue with other bluetooth audio devices?
