23+ battery/charging issues/camera issues
(Topic created: 05-05-2025 07:42 AM)
sidm902
Galaxy S23
After the new update,battery usage is horrible and continues to be horrible after almost a full week. Also, when taking a picture,they are blurry when zoomed in even if the lens is clean. My galaxy also stopped charging with certain cords. I used a factory cord and it still wouldn't charge.
Mujibar
Black Hole
Galaxy S23
If you haven't already cleared device cache, you should. See this post for more info:
https://us.community.samsung.com/t5/Galaxy-S-Phones/Battery-drainage-on-One-UI-7/td-p/3220005?src=Sh...
sidm902
Galaxy S23
I did do that still the same results
Mujibar
Black Hole
Galaxy S23
You may need to give it some more time for the battery to settle in.
As for the charging, you've tried different cables but have you tried a different charger?
sidm902
Galaxy S23
Yes I found one that works thankfully
usergHoniG6Mei
Galaxy S23
None of these suggestiins are helpful😮
sidm902
Galaxy S23
Another issue i ran into is that I no longer have 5g service,and yes it's included in my plan
