userdIFRJCwycn
- Mute
ā05-30-2025
04:49 AM
(Last edited
ā05-30-2025
05:39 AM
by
SamsungRei
) in
I'm not impressed with the recent version 15 upgrade after the long wait for the release. Can't pull down anywhere for notifications except on the far left otherwise, you get another pull down screen. Battery has a bit more drain after the upgrade.
DC856
- Mute
ā05-30-2025 05:00 AM in
Galaxy S23
There is a fix for that in the settings. Pull down from the right, hit the pencil icon at the top, hit panel settings at the top, then choose together instead of separate. Easy fix
userdIFRJCwycn
- Mute
ā05-30-2025 07:31 AM in
Galaxy S23
Thank you š
