Notification sound for group texts.
(Topic created: 09-08-2023 09:36 AM)
userciKharBBTl
Galaxy S23
Previously when I would open a group text message there was a menu option to change notification sound. It is no longer there (it still exists in the menu for individual text messages). I can no longer figure out how to change the notification sound for a group message.
SamsungModerator1
Galaxy S23
Thank you for confirming this information.  We appreciate your feedback and will tag it on the forum so that it will appear with other feedback, ideas, and requests. This will allow your post to be more easily found in the event that Samsung product groups are seeking outside feedback/requests/ideas regarding our products.
We also recommend submitting an error report through the Members app to provide feedback to the developers. https://www.samsung.com/ae/support/mobile-devices/raising-an-error-report-via-samsung-members-app/
lasr8
Galaxy S23
Same problem
SamsungModerator1
Galaxy S23
I can certainly understand your confusion with changing this setting. Thanks for bringing this matter to our attention. If I'm not mistaken, you can change the notification of the group chat by going to Contacts, tapping (three horizontal lines) Show navigation menu > Groups. There you should be able to edit the group and change the sound the group makes when you receive a notification. Let us know if this helps.
user0e3GNpY5nz
Galaxy S23
No this doesn't answer it. In messages, before recent update, I have a group chat with my coworkers. I had it where anyone I got a notification from that specific chat I could get a specific sound, it works on individual chats. The group chat rings multiple times a day and by hearing their specific sound I know I don't need to check right away. So by having to change each individuals tone to the same sound I'm not solving the problem I'm trying to. Go back to being able to give convo threads their own sounds
SamsungModerator1
Galaxy S23
