S23: Help Connecting My Bluetooth Device ; Phone is not seeing it.
(Topic created: 02-20-2024 07:27 PM)
Jimbo1620
Galaxy S23
I had a camera remote control that was laid to my phone via Bluetooth. Last Thursday I accidentally deleted it from Paired and now I can't get the phone to see it. Is the pairing not totally lost?
LeoWyatt89
Comet
Galaxy S23
Hello, this is no issue at all. All you have to do is put the device (in this case the camera remote control) back into pairing mode so the phone can recognize it. Contact the manufacturer of the remote, and they should be able to tell you how to put it in pairing mode. If it's still not seeing it try resetting the Bluetooth settings Go to Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile, & Bluetooth > Reset settings
Jimbo1620
Galaxy S23
I did try pairing but phone didn't see the remote. It's Chinese so no USA support avail. I'll try your other option of reset Bluetooth. Thanks so much!
