Semi-solution to heating and battery issues
(Topic created: 04-01-2024 09:28 PM)
Shojannah
Galaxy S23
The heating and battery life issues are caused by the new battery protect feature, in my experience when I turn it off my phone lasts as long as it always has and doesn't feel warm by just doing nothing, it doesn't matter what setting you have it set to, it's genuinely detrimental to battery life if it's working in the background in any capacity (which is admittedly very backwards and paradoxical as it's meant to enhance said battery life.)
Personally, I find using a routine to protect the battery much more effective with the added advantage that it's more tailorable to your preferences.
I've attached a screenshot to show how I have my basic routine set for anyone to use as a guideline if you still want such a feature without the impact to temperature.
1 Reply
notforhire
Honored Contributor
Galaxy S23
hopefully, this is helpful for some people 👍
