Jeffry0001
- Mute
04-30-2025 04:27 PM in
Galaxy S23- In the One UI 7 Beta I had problems with the battery widget icon, the same thing happens on the lock screen, it also affects some weather widgets on the lock screen, I thought that since the Beta it would be fixed but now that I have One UI 7 stable, it wasn't like that.
realaud
Honored Contributor
- Mute
04-30-2025 06:27 PM in
Galaxy S23
What exactly is the issue?
Jeffry0001
- Mute
04-30-2025 06:52 PM in
Galaxy S23
I have the battery widgets as seen above and the battery percentage is above the device icon and it should look like the image below.
realaud
Honored Contributor
- Mute
04-30-2025 06:58 PM in
Galaxy S23
Ok. I see now, that's odd. Have you tried a) a reboot, b) clearing the phone cache? If a reboot doesn't fix it, clear the cache. If that doesn't fix it, pug in an error report and attach the pictures.
Jeffry0001
- Mute
04-30-2025 07:07 PM in
Galaxy S23
How do I clear the phone's cache?
realaud
Honored Contributor
- Mute
04-30-2025 07:11 PM in
Galaxy S23
To clear the phone cache:
1. Power off your phone. Hold Power and vol up buttons until Samsung Logo appears
2. Let go of both buttons when you see the Samsung Logo appear on screen. There will be a delay while it enters recovery mode.
3. Use the volume buttons to navigate through recovery menu options and highlight “Wipe Cache Partition.” Press power button to select this option. Confirm by navigating to the yes response and tapping the power button to select.
5. When wiping cache partition is complete, "reboot system now" should be highlighted; press power key to select it. The phone will reboot as normal.
