Constant battery charging notification when charging on S24
(Topic created: 04-25-2024 03:32 PM)
GreerS24
Galaxy S24
When I have my S24 on charge the battery charging notification shows on top of other apps every few seconds and the phone vibrates. It is difficult to use the phone when charging. Does anyone know how to turn this off? I have been though the settings many times but can't seem to resolve. Any help is appreciated.
neilth
Red Giant
Galaxy S24
Could someone have created on your phone a mode or a routine dealing with battery charging and generating the vibrations and notifications?
LadyGray4110
Cosmic Ray
Galaxy S24
Try this. Go to settings. At the very top in the Search spyglass, type in System Vibration Intensity. You should see a list of options. Scroll to where it says "charger" and move the slider to the left. That should solve it for the time being. The other thing you might want to check is your connection. If your cable is loosely connected it can also trigger the notification.
