[Galaxy S25 Series] How to fix Knox Matrix draining battery and overheating phone
(Topic created: 4 weeks ago)
Galaxy S25
Knox Matrix is draining the battery and overheating the phone. Impossible to work that way. I hope that Samsung publish an update soon to fix this. I'm concerned that the battery can start expanding or leaking because it is to hot and i need to keep the phone charging to go thru my work shift. Really bad situation...
SamsungMod
Galaxy S25
Hey Sergio_Blanco! Thanks for visiting the Community! Let's see what we can do to get your battery operating as it should.
Give this link a shot to get the battery draining under control
http://www.samsung.com/us/support/troubleshoot/TSG10001538/
This link should help with keeping your device temperature at a reasonable degree.
https://www.samsung.com/us/support/answer/ANS10002887/
Thanks to PandoraB, we have another option to try.
Go to the Device Care settings, changed the Performance Profile from 'Standard' to 'Light'. Then go to Settings-Apps-Search-Knox app. 3 menu button, "UNINSTALL UPDATES". Then "go to Galaxy Store" from within Knox app menu still, update app again, and that cleared the entire overheating and battery drain.
Let the phone charge while still in Light performance mode and once you're sure it wasn't going to overheat again after it finished charging at 100%, change it to standard performance mode.
If this does not help I recommend letting a service technician have a look. As we would like to gather additional information, and look at this from a case by case basis, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
Be sure to click " โœ“ Accept as Solution" when you find an answer that works for you.
LongHiker
Galactic Samsung Care Ambassador
Galaxy S25
SamsungMod
Galaxy S25
Galaxy S25
None of the links considered the knox matrix app...
Galaxy S25
By the way the problem started immediately after the last update
Galaxy S25
The problem will not be resolved until a patch or a new update accounts for the knox matrix app overwhelming the cpu and overheating the phone
PandoraB
Cosmic Ray
Galaxy S25
Hey, I found a workaround on my end after seeing other posts and commenting, etc.
I went into the Device Care settings, changed the Performance Profile from 'Standard' to 'Light'. Then I went to Settings-Apps-Search-Knox app. 3 menu button, "UNINSTALL UPDATES". Then "go to Galaxy Store" from within Knox app menu still, update app again, and that cleared the entire overheating and battery drain.
I let the phone charge while still in Light performance mode and once I was sure it wasn't going to overheat again after it finished charging at 100%, I changed it to standard performance mode.
It's been 2 days and I haven't had a single issue since.
DinoHeather
Galaxy S25
Just tried this and I'm already seeing a difference! Thank you!๐Ÿซถ๐Ÿผ
coolkid10293
Galaxy S25
This worked my battery life is back to normal and I haven't seen any issues
SamsungMod
Galaxy S25
Thank you so much for this! I have added it to the accepted solution. Please keep being one of the best parts of Community!!!!
