- Mute
โ02-14-2026 08:29 AM in
Galaxy S25Five days ago I upgraded my Samsung Galaxy Note 20 Ultra to a Galaxy S25 Ultra. I used Smart Switch thinking EVERYTHING would transfer including app notifications. Wrong! After four days of hair pulling and research, I put together the following procedure that worked the first time I tried it. I hope this helps!
To reset to app provided sound notifications on a Samsung Galaxy S25 Ultra,
Settings > Apps, tap the three-dot menu (top right), and select Reset app preferences. This action restores default notification settings, permissions, and background data restrictions for all apps, fixing issues with hidden or malfunctioning alerts.
Steps to Reset Notification Preferences:
Open Settings.
Tap on Apps.
Tap the three-dot menu icon in the top right corner.
Select Reset app preferences.
Tap Reset to confirm.
Restart the phone.
After you Reset App Preferences:
Go to Settings > Apps.
Select the specific app.
Tapping Notifications and toggling them off and on, or adjusting specific notification categories.
There will be third party apps with notifications turned off. To turn on the notifications for the specific apps, click โNotification Categoriesโ. You will most likely see a grayed out message โNo Categories Availableโ. Ignore the message and turn on notification for the desired apps. Restart the phone. The app provided sound will be used the next time apps send a notification.
Galaxy Watch paired with your phone:
Open The Wearable app.
Watch Settings > Notifications > App Notifications.
Select the apps you want notifications on your watch.
Sources: Google AI
- Mute
โ02-14-2026 10:26 AM in
Galaxy S25This seems like a helpful guide on transferring data. Thank you for sharing your dilemma with us and for how you resolved it.
- Mute
โ02-15-2026 11:57 AM in
Galaxy S25- Mark as New
- Mute
โ02-15-2026 12:03 PM in
Galaxy S25
