Highlighted
Alarm doesn't sound and is not shown in lock screen
Since the last updates (both System and Samsung's  Alarm app), my alarms aren't working.
First, it was just on the lock screen. It shows "No alarms in the next 7 days", no matter how many programmed alarms I have.
Then, it started to fail and now it doesn't even sound. Tried already without Do Not Disturb mode (which I use to sleep at night), and it is not working either.
Alarm widget vanishes also from the screen.
As I said before, I think it had something to do with the updates. Specially on the lock screen. The Spotify play/pause command doesn't work either. Everything on FaceWidget is failing.
Any idea when are you going to be fixing these major bugs?
