Both Cameras, Flashlight and Iris Scanner are not working
my phone had faced a nasty drop which resulted in shattering the screen and bending the frame
luckily other components were functional
or so i thought
after a screen replacement the phone was functional but the camera app was closing immediately
and the iris scanner was not functioning with a message to restart the phone
the flashlight message was that the flash is being used in another app
so i checked it in test mode *#0*#
the cameras were displaying a message "the number of camera is 0"
iris scanner message was "$Change: 15177986 $$Revision: #2 $" with black where iris scanner was supposed to be displayed
i replaced the cameras and iris scanner with known good and still the same issue
3 REPLIES 3
Re: Both Cameras, Flashlight and Iris Scanner are not working
Hello,
Did you have your device repaired with Samsung or a third-party repair shop?
none
Repaired personally
As self repair has been performed on the device, it wouldn't be covered my Samsung Standard limited warranty. I would recommend a service repair. If you wish to set your device up for service, I would recommend contacting our customer service team directly at 1-800-726-7864 for further assistance.
