userI3LJVn9b7u
Can't set a separate notification sound for messaging?
JUMP TO SOLUTION
I just got my S8+ and I'm trying to set up a text message tone, and no matter what I do, it won't change.
I went into the Messaging app's settings and changed it from there (I've tried using an alert I downloaded, as well as I've tried with one of the default ones). It shows that I've changed it there, but every time I get a text it still plays my default notification sound.
Anyone experienced this and have a fix?
1 SOLUTION
Ezzysensei
Re: Can't set a separate notification sound for messaging?
JUMP TO SOLUTION
Hi! I figured it out on accident as this was a similar gripe for me. You can change this for any individual contact once you are in that contact's message thread. Hit the triple dot menu. From there, the first option is Notifications. It should read Default.  The option below it is Custom. Once you select Custom,  The Gear icon should be available to select and you can choose your custom notification from there. Best of luck!
7 REPLIES 7
Ezzysensei
JUMP TO SOLUTION
JUMP TO SOLUTION
Important to note that this is a half baked fix from samsung and if you delete those threads you will have to reassign your text alerts.  Samsung refuses to return the feature properly and there is a massive thread on this site about it.
userQMq9MdcNyE
JUMP TO SOLUTION
I used to have separate notification sound for messages.  (S8+) now it's gone.... seriously?!
Angry customer! Samsung,  quit taking away and try adding instead! I paid almost $1000 for this phone for you to mess up my settings?!
userhvKmhFp7Is
JUMP TO SOLUTION
So glad I've come across this thread. I got a Samsung s9 on Saturday and I've been trying ever since to sort this out without success. Thought I had a faulty handset but do I take it it's a problem across the board with samsung, by the way just upgraded from an s6 which didn't have this problem.
Samsung_XM5vHTa
U have to go in ur settings and press notification and ri...
JUMP TO SOLUTION
U have to go in ur settings and press notification and ringtones and that will pop up with whatever you need
user5bxeQtqWYY
Re: U have to go in ur settings and press notification and ri...
JUMP TO SOLUTION
Not True.  There is no option to change notification sound for messages.  Only options is to change sound for ALL NOTIFICATIONS.  This is beyond stupid for Samsung or Android to do this.  Wish I would have stuck with iphone.
userPA3gXvEZfU
JUMP TO SOLUTION
Actually, Samsung_XM5vHTa  is correct. Thank you. However there is a subtlety...
Go into Settings | Notifications
Part way down the screen you'll see a section labelled "Resently sent". I think this is a list of the apps which most recently sounded a notification. If you change the sound from this list, it seems to work.
Good luck.
