Slowbusa
Cosmic Ray
Do not Disturb doesn't work....
JUMP TO SOLUTION
If I use Do not Disturb with Alarms only everything is fine, my phone is all quiet until an alarm goes off.  When I switch to Exceptions I get all alarms, texts notifications, and phone calls.
S8+ running oreo 8.0.  This issue is not new with Oreo.
1 SOLUTION
Slowbusa
Cosmic Ray
Re: Do not Disturb doesn't work....
JUMP TO SOLUTION
well i finally figured out my own issue.  The problem is, Do not disturb custom exceptions DOES NOT WORK WITH VERIZON MESSAGES+
When I switch to the native samsung messaging app, the custom exceptions works as stated.  This is very frustrating.
8 REPLIES 8
Slowbusa
Cosmic Ray
JUMP TO SOLUTION
I should clarify, I have exceptions set to calls and texts from favorites only.
I verified that I only have 2 favorites listed in my contacts section, and I'm using Verizon Messages + as my default messaging app.
Slowbusa
Cosmic Ray
JUMP TO SOLUTION
Any help?
useraQ9agQap85
JUMP TO SOLUTION
s8 plus doing same thing since Oreo... called Samsung and they can not fix. it only works if u don't allow exceptions. please Samsung fix this
Slowbusa
Cosmic Ray
JUMP TO SOLUTION
mine has done it since before oreo.  But yeah it wont work unless you do NOT allow exceptions.
Slowbusa
Cosmic Ray
JUMP TO SOLUTION
glad to see none of the Samsung tech's chiming in.
Slowbusa
Cosmic Ray
JUMP TO SOLUTION
userfQaZ2xshwh
JUMP TO SOLUTION
Please explain the steps to complete this. I have TMobile & have the same issue .
userfQaZ2xshwh
JUMP TO SOLUTION
It's basically pointless. This is frustrating.
