userAEy3GnkRhO
Re: Galaxy S8 SD Card Problems.
JUMP TO SOLUTION
I'm having the exact same issue
Wardak96
Cosmic Ray
JUMP TO SOLUTION
Thought I would show a screenshot of the issue. As you can see, it states that the SD card is not inserted, but I know for a fact that it is in there. After a few seconds it'll work again. This, although a minor issue, is kind of concerning considering it's a top of the line phone paired with a top of the line SD card. And I am really hoping this is just a software issue that can be fixed with an update.
Honored Contributor
JUMP TO SOLUTION
Has anyone been able to open and try to move the tray physically with their hand to see if perhaps it triggers it to be re-mounted. Or is it just not even being found at all any longer?
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you. If a post stand out to you, perhaps you could give that post a star to show other community members they were able to assist or was relevant to you.
userpTjLKvY2Gn
JUMP TO SOLUTION
I've taken it out, put it back, rebooted& turned phone offand on. The sd card works in my other phones just not recognised by the s8+. When will samsung fix this or start sending out new phones?
JUMP TO SOLUTION
The tray is nice and tight. The phone reads the sd card fine, for me at least, but it would randomly disappear and reappear as stated by many users. I don't have any apps installed on the sd card so I'm not getting as much errors as most people are that have apps installed in their sd card. I do have my music files in my sd card and sometimes my music app can't load my music folder from the sd card because it telling the app that there's no sd card even though there is. For me it's very rare that it happens but when it does happen it's really frustrating. This should not happen at all period. And the other annoying thing that happens is, a few times a day I would get a notification as if my sd card was just put in the phone so then I get a notification that says, "tap here to transfer files...". So please, look into this. I love my s8+ and I really don't wanna have to return it but I will if this issue doesn't get resolved.
e1000
JUMP TO SOLUTION
T-Mobile Galaxy S8 experiencing this problem. I've tried:
- Different SD cards from various brands and sizes: Samsung 256GB EVO+ (x2), Samsung 128GB Pro+, Sandisk Ultra 200GB, Samsung 32GB EVO+, Sandisk Extreme Plus 64GB. I've tried both exFAT and FAT32
- Tried running the card Encrypted and decrypted. While decrypted, apps will sometimes throw an error, but otherwise there isn't a defined notification. While encrypted, every time the card gets unmounted, there will be a SD Card Encrypted notification
- Tried leaving the card inserted, but manually unmounting the card. The card should stay unmounted, but it doesn't
- Used an app called SD Card Monitor, shows that the card is being ejected, unmounted and then re-mounted over and over again
- Tried clearing cache via bootloader
- Smartswitch errors while trying to backup to SD
- Large file transfers to SD almost always fail
- Safe mode - encrypted card still throws notifications
Under all circumstances, the card unmounts and re-mounts periodically. Time duration varies, can be as quick as every 5 minutes to every hour or so.
userf9MplVzlnQ
JUMP TO SOLUTION
I've tried 2 cards - 1 which works perfectly in my old s7 Edge, the other brand new.
I ended up reformatting the older card (SanDisk 64gb purchased in Feb 2017 - I.e 2 months old) and tried it again - same problems.
Tried a brand new Samsung Evo 128gb card, formatted in the phone - even worse than the SanDisk.  Of the 1400 photos transferred from my PC to the phone - only 1 had a visible thumbnail, the rest were greyed out icons.  When I tried to open the only good photo, nothing happened for several seconds - it finally opened, but most of the photo was greyed out.
Reformatted the card again.  This time transferred all the photos from the PC to the phone's internal memory.  They all were perfect - both thumbnail and actual photo.   Then I transferred them from internal phone memory to SD card.
Same old problems instantly reappeared.  Most thumbnails greyed out, the 1 photo I could open took over 30 seconds to open.
I didn't bother putting any music on the card - pointless.
Ended up removing the card.
I have had other issues with the phone (failed restore from Smart Switch) that even a Samsung tech couldn't get to work.
And now the SD card debacle.  After the issues surrounding the Note 7 and its recall, I am very disappointed that the beautiful new s8+ is so problematic from day 1.   You would have thought that Samsung would so thoroughly test this phone it would be problem free from the get go.
Samsung - we need either a software fix or replacement phones.
thanks.
userz1d1Ogn0hF
JUMP TO SOLUTION
I too am having issues with the sd card and my S8+. The card will randomly.mount and unmount. This card was part of the preorder bundle and appears to work well with other devices.
With this many reports, this has to be a software issue of some kind.  I've yet to see any replies from Samsung on this thread. Hopefully they will issue a fix soon. Otherwise I will have to return the device.
userbAzYbh9ByA
JUMP TO SOLUTION
It's not being found at all,  if I click storage it only gives me the they internal storage numbers.  I've tried ejecting the tray and pushing it back in, restarting the phone as well. I noticed this issue when I got the vr head set 2 days ago. Friday I could access the card.  Yesterday it wasn't even reading and got a notification saying it was ejected.
userbAzYbh9ByA
JUMP TO SOLUTION
It doesn't recognize the card either when I restart the phone nor does the sd card monitor app and I never used the app power monitor
