userpkPmUYC88N
Galaxy S8 camera quick launch problem?
JUMP TO SOLUTION
So when I press the power button on my S8 to look at the time, the camera will randomly turn on from a single press of the button instead of the 2 quick presses of the button. Anyone else have that problem? Any solution besides turning off the feature altogether that anyone knows of?
-thanks
1 SOLUTION
Honored Contributor
Re: Galaxy S8 camera quick launch problem?
JUMP TO SOLUTION
Hello there, @userpkPmUYC88N
Let's try some troubleshooting steps, just let us know how these go!
  1. Are all your Apps are up to date? You have 2 places that you need to look. Google Play store and Galaxy app store. Go to both and check My Apps. Make sure there is no app that needs updating.
  2. Is your phone OS up to date? Go to Settings, About phone and check for software update. Make sure you have the latest phone software.
  3. Clear phone cache. Instructions are here
  4. Restart your phone in Safe mode. This is just to help you isolate the issue if it is caused by 3rd part apps. Instructions are here
If those don't help, we certainly want to assist you further with this matter. To better do that, can we have some added details about your specific device and this concern? Things that will help the most would be the exact model number and Baseband version (both under Settings>About Device) for your device as well as your carrier and when you started noticing this happen. Thanks!
11 REPLIES 11
Honored Contributor
JUMP TO SOLUTION
userpkPmUYC88N
JUMP TO SOLUTION
I've followed the steps suggested and now I'll wait to see if the problem continues.
-thanks
Honored Contributor
JUMP TO SOLUTION
No problem! Just let us know if things start acting up again.  Smiley Happy
userpkPmUYC88N
JUMP TO SOLUTION
So after clearing the cache, my galaxy s8's camera quick launch was not randomly turning on with a single press of the power button for almost the whole week, it did come on twice yesterday though when i went to look at the time, maybe the cache needs to be cleared periodically to keep the issue away, also, my phone did a system update yesterday when i got home from work So maybe the problem could have been patched through the update.
user5sNvnpnSoF
JUMP TO SOLUTION
I am having the same issue with my phone.  I have tried a software reset and clearing the cache.
Honored Contributor
JUMP TO SOLUTION
@user5sNvnpnSoF
Have you had a moment to try and of the other suggestions from this thread?
user5sNvnpnSoF
JUMP TO SOLUTION
Yep.  The issue seems to subside for a while after clearing the cache, but it ends up coming back.  I made a Reddit post and at least one other person has this issue as well.  I am hoping that the software debouncing is tweaked on the power button or that a bug is identified and patched.
userM84lhEdRVz
JUMP TO SOLUTION
I also have this problem.
Red Giant
JUMP TO SOLUTION
Good afternoon @userM84lhEdRVz
Have you tried any of the troubleshooting methods we listed above? Just double checking so that I know what you have and haven't tried already.
