Showing results forย
Search instead forย
Did you mean:ย
JoMack313
Help with battery life for S8+
JUMP TO SOLUTION
When I got the S8+ sometime in June of 2017 it was working great It was brand new and had about 24hrs worth of battery life. It stayed that way. A few months ago if fell broke and I had to pay for a new one thought the at&t insurance. This phone came 15 battery life ๐Ÿ˜‘. I got up at six this morning and the battery is already at 72% that's without using the phone. My screen brightness is super low and it still to up 5% of the battery life while the Android system took up 4%. At this right my phone will be dead in 2 hours if I listen to spotify or watch Netflix or youtube
1 SOLUTION
Gfang
Re: Help with battery life for S8+
JUMP TO SOLUTION
My siggto you is to turn off always on display. I know it's one of the main features but you still have the notification led. Also you can try putting it in Power Saving mode to help conserve more power.
2 REPLIES 2
Gfang
JUMP TO SOLUTION
JoMack313
JUMP TO SOLUTION
Thank you i will try it out
