userQzixlG7qGK
In call volume low with volume at max setting
JUMP TO SOLUTION
For a couple of weeks now my in call volume has been really low with the volume setting all the way up, I've cleared the cache partition and deleted the last app i downloaded before it happened but still no luck. Any suggestions??
1 SOLUTION
Re: In call volume low with volume at max setting
JUMP TO SOLUTION
To put your device in safe mode, press the power button the side, then when you see the power off option press and hold until you see safe mode populate. Tap on safe mode.
8 REPLIES 8
JUMP TO SOLUTION
Can I have your full model code?
userQzixlG7qGK
JUMP TO SOLUTION
SM-G950FZKAXSA
JUMP TO SOLUTION
Is there a difference in the volume if you try calling someone while your phone is in safe mode?
userQzixlG7qGK
JUMP TO SOLUTION
How do i put it in safe mode
JUMP TO SOLUTION
userQzixlG7qGK
JUMP TO SOLUTION
Ok i put my phone into safe mode and it was fine, the in call volume was normal
userQzixlG7qGK
JUMP TO SOLUTION
Pit it back to normal mode and the in call volume is low again
JUMP TO SOLUTION
Your symptom is being caused by a third-party application that you downloaded. When you placed your device in safe mode, it disabled third-party applications from running and your issue stopped.
I would recommend removing recently installed applications until your issue does not happen when you are out of safe mode.
Hope this message finds you well!
^SamsungZell
