Highlighted
Incoming volume low
Hi, my mobile is galaxy s8 and I face issue while calling. My incoming voice is very low. I keep speaking using loud speaker only
2 REPLIES 2
Highlighted
Galaxy
Re: Incoming volume low
maybe u have to clean your phone speaker or fix it at a samsung tech store. hope that this helped you
Highlighted
If your still having problems this should help.
You'll need dental floss pick use sharp end and can of air. SOFTLY rub pick end across mic and then use can air to get rid of debris. BE GENTLE. If you used liquid cover it will over time collect into mic.
