- Mute
- Email to a Friend
06-29-2017 07:35 AM in
Galaxy S8Charger says it has an incomplete connect. Second day, has anyone else had this issue? Miserable, stuck to the wall!
Solved! Go to Solution.
- Tags:
- Adaptive
- Mute
- Email to a Friend
08-07-2018 08:36 AM in
Galaxy S8Hello. I followed the first two steps but I do not see an option for Battery under Show System Apps. Thanks.
- Mute
- Email to a Friend
08-07-2018 08:51 AM in
Galaxy S8Okay, thank you for the response. Can you please provide me with the model number and baseband version of your device?
- Mute
- Email to a Friend
08-07-2018 09:31 AM in
Galaxy S8
@SamsungJace wrote:Okay, thank you for the response. Can you please provide me with the model number and baseband version of your device?
Model: SM-G950U
Baseband: G950USQS5CRF5
- Mute
- Email to a Friend
08-07-2018 12:01 PM in
Galaxy S8Also, does the phone fast charge if you have the USB cable connected into the fast charging adapter piece?
- Mute
- Email to a Friend
08-08-2018 04:39 PM in
Galaxy S8
@SamsungJace wrote:Also, does the phone fast charge if you have the USB cable connected into the fast charging adapter piece?
I have tried a few things. The Samsung wall charger provided with the phone does not work. Fast charging does not work. Regular wall chargers (non-fast charging) using Samsung USB-C cable charges phone.
Incomplete connection error message appears when attaching phone to a computer or to my car when using ANY USB-C cable.
Getting very frustrated
- Mute
- Email to a Friend
08-12-2018 06:17 AM in
Galaxy S8Can I have your carrier information?
- Mute
- Email to a Friend
08-12-2018 06:28 AM in
Galaxy S8Verizon. I have 5 type C chords and 2 black fast charge plugs that came with samsung s8 and s9. NONE will fast charge. why on EARTH would a carrier have anything to do with this? Are you gonna ask which hand we use to connect our phones with next?
@SamsungLarryK wrote:Can I have your carrier information?
- Mute
- Email to a Friend
08-12-2018 07:05 AM in
Galaxy S8You need to reach out to your carrier for a software update. The software version is currently G950USQU4CRE9.
- Mute
- Email to a Friend
08-12-2018 07:26 AM in
Galaxy S8That is my software version.
- Mute
- Email to a Friend
08-12-2018 07:46 AM in
Galaxy S8
I apologize that wasn't meant for you. Have you tried charging your device while it is in safe mode?
