- Mute
- Email to a Friend
06-29-2017 07:35 AM in
Galaxy S8Charger says it has an incomplete connect. Second day, has anyone else had this issue? Miserable, stuck to the wall!
Solved! Go to Solution.
- Tags:
- Adaptive
- Mute
- Email to a Friend
07-17-2017 10:16 AM in
Galaxy S8This seems to be a problem with a limited number of devices. I'd like to gather some information from those of you seeing this though!
Things that will help the most would be the exact model number and Baseband version (both under Settings>About Device) for your device as well as your carrier, when you started noticing this happen, and what you've already tried to fix it. Thanks!
- Mute
- Email to a Friend
07-17-2017 02:24 PM in
Galaxy S8I starting experiencing this same problem starting on 7/10/17.
- Using original charging cable and brick
- Sometimes it does not charge at all, but when it does it's always incomplete connection
- Wireless charging no longer fast charges
- Wireless charging does not charge to 100%
Troubleshooting
- Blown out port with air
- Swabbed port with rubbing alcohol
- Disabled Fast Cable Charging
- Powered on/off device
- Tried other Samsung cables and bricks
- Confirmed Cable/Brick combination works correctly in other Samsung S8 device
Device Details:
- Model #: SM-G950U
- Baseband: G950USQU1AQEF
- Carrier: Verizon
- Andriod Version: 7.0
- Mute
- Email to a Friend
07-17-2017 02:46 PM in
Galaxy S8I had the same charging problem using the supplied charger and cable. The charging port on the phone proved to be the problem. I exchanged the S8 for another and the cable fit much tighter. Looks like a batch was defective.
- Mute
- Email to a Friend
07-18-2017 07:34 AM in
Galaxy S8Sounds like an evaluation and repair is in order. Definitely reach out to Samsung directly via Phone (1-800-SAMSUNG/1-800-726-7864), Twitter, or even Facebook.
Likewise, you can always reach out to your carriers for an exchange like @userKMCLZoHoK4 mentioned. :)
- Mute
- Email to a Friend
08-16-2017 07:27 AM in
Galaxy S8My daughter's S8 began having this exact problem. She leaves it on the Samsung original equipment charger all night. It only reaches 5% charge. I was going to buy a Samsung Galaxy S8+ next week, but now I am reconsidering. How is Samsung going to fix the S8 and S8+ phones? Last week, I had a Galaxy S7 Edge blow up. It caught on fire and smoked for many minutes. I've always thought that Samsung phones were the best, but these issues are becoming a big problem.
- Mute
- Email to a Friend
01-29-2018 12:00 PM (Last edited 01-29-2018 12:14 PM ) in
Galaxy S8I purchased a bag that comes with a joey charger to use with mobile phones and got the incomplete connection error message. I called your number and was told that you can only charge your phone with a power source from Samsung. That's pretty manipulative and lame. Why should this be any different from plugging into the wall or a computer to charge???
I called again and the person i spoke with this time said that you can charge with other sources as long as you use the Samsung cord and to contact the company that made the power bank...
- Mute
- Email to a Friend
01-31-2018 02:40 PM in
Galaxy S8I am having the same problem; I had to return my phone after 2 months they sent me a new one which worked for a while but now I am getting the same incomplete connection message. This is super frustrating Samsung has gone wayyyyy downhill with the S8!
- Mute
- Email to a Friend
07-29-2017 11:18 AM in
Galaxy S8After two weeks of no resolution, I called Samsung and they wanted me to rest my phone. I didn't want to go through that process, so I took my device to a Verizon store. We plugged the device into multiple chargers with no success. Verizon recommended I replace the phone.
Thinking the port is dirty, I went to clean it one more time. I used compressed air and this time added suction from a vacuum. I plugged the device back into a USB-C charger and it started working as normal. I was surprised.
My assumption is there were dust or sand particles that were causing the problem.
- Mute
- Email to a Friend
09-17-2017 07:07 PM in
Galaxy S8My phones not even a mobth old and its giving me a irregular charge ...after spending hundreds on this phone you thinkthe charger wouldnot be and issue
- Mute
- Email to a Friend
09-18-2017 09:06 AM in
Galaxy S8This just started for me in the last 2 days, all of my chargers do this now. I've had limited success rotating the USB-C plug. Sometimes that will clear it up.
