Highlighted
Re: Low Call Volume On S8+
I've tried that as well with the same result. Can it be a hardware problem.?
Highlighted
Checking to see if you still need any assistance?
Highlighted
After doing many things it still remains the same.
Highlighted
Give these steps below a try, if this doesn't work I would recommend the various service options. You are welcome to speak with your carrier to see what they can offer, you can have Best Buy's Samsung Experience Shop evaluate for software related causes, OR Samsung can help you send the device into an authorized service center to have our technicians evaluate for both software/hardware causes.
For the microphone, there are 3 apps under system apps named Phone, use these steps for each app named phone:
Settings> Apps> 3 Vertical Dots> Show System Apps> Phone> Storage> Clear Cache> Clear Data
Highlighted
Why would it be the device if this happened after a phone update?
Highlighted
Honored Contributor
Hello everyone, we have updated Sebas's response. Could you give those steps a try? If these steps don't work we would recommend the service options.
Highlighted
Did you e ever get that volume issue solved?
Highlighted
Again, a link that goes to a general page, not specifically to the topic
Not very helpful
Highlighted
Mine is the same thing . You cant hear your in coming calls.
Highlighted
Did you ever find a fix because my husband is having the same problem.
