Highlighted
Multimedia messages not sending when Wifi is connected on phone
Hi. I have a Samsung Galaxy S8 phone. I have never had any problems sending/receiving multimedia messages until 3 days ago.
If I connect to wifi, I do not receive them. Once I turn the wifi off on my phone, that's when the multimedia messages come through.
I am a photographer so this HAS to be corrected. I need help ASAP!!! Thanks.
2 REPLIES 2
Highlighted
Supernova
Re: Multimedia messages not sending when Wifi is connected on phone
@MomXs6
here's a great help article on this exact issue: https://thedroidguy.com/galaxy-s8-plus-wont-send-mms-when-connected-to-wifi-mobile-data-and-roaming-...
If one of the steps there helps let us know by selecting this and commenting with the step.
Did this reply help? Be sure to click" ✓ Accept as Solution" if you found this reply solved your issue or pointed you in the right direction. You can also click the heart to let me know your appreciation!
Highlighted
Supernova
@MomXs6
Did this end up helping you? Let me know if so by accepting it as the solution. This will help others find that as well.
