userH6j1TRcVeC
Phone Vibrating for Text Notifications When Sound Is On
JUMP TO SOLUTION
2 days ago, my S8 started vibrating for text message notifictions (Message+ app with Verizon) even though the phone is set to sound notifications. I've checked in the Message+ app and it is set to vibrate only when the phone is set to vibrate. I spoke to a Verizon rep last night and we found under Settings -> Sound & Vibration -> Notification Sounds -> Message Notifications that Vibrate when sound plays was turned on. We turned it off and the problem ended. Today it started vibrating again after I set my phone to silent and then turned it back to sound.  I checked the same setting and it still shows off. I'm at a loss!
1 SOLUTION
Red Giant
Re: Phone Vibrating for Text Notifications When Sound Is On
JUMP TO SOLUTION
@userH6j1TRcVeC
Well I am glad that we were at least able to isolate that concern to the Message+ app. I would reach out to Verizon support, and see if they have a work around for that software if you want to keep using that application.
4 REPLIES 4
Red Giant
JUMP TO SOLUTION
Good afternoon @userH6j1TRcVeC
Do you know if these same notification errors occur if you use a different texting app? I understand that Messages+ is the default on Verizon devices, but I would like to see if it is an error only within that app, or across all messenger apps.
userH6j1TRcVeC
JUMP TO SOLUTION
Thank you for getting back to me! I just downloaded the Textra app and so far not having any issues. My phone is set to sound and when receiving a text it is no longer vibrating along with the sound. So I guess this is a message plus issue!
userH6j1TRcVeC
JUMP TO SOLUTION
Red Giant
JUMP TO SOLUTION
@userH6j1TRcVeC
