Contact names not showing up on incoming calls
(Topic created: 04-19-2019 02:04 PM)
userWb4WZNe8w5
Galaxy S Phones
I have a galaxy s8 plus. When I receive incoming calls from a contact in my phone book only their number displays. But when I go in my recent calls both their name and number is there. Like most people I don't know everyone's phone number so when people are calling me, I don't know who they are until after I miss it. I've already tried restarting my phone. No luck And I checked for a software update. It's up to date.
JUMP TO SOLUTION
userbCwOCovY1N
Galaxy S Phones
Thanks for helping! Mine is working now.
userd8zhHlFfR4
Galaxy S Phones
What did you do?
J0kerassassin
Galaxy S Phones
I believe in a previous post a few people were saying that it was a Samsung issue that they are still trying to fix.
SamsungRei
Galaxy S Phones
Hey guys,
Go to your Settings>Applications>Search for an application called "Call Protect".
When you open it, select Force stop.
userr4FWAxB1od
Galaxy S Phones
That worked! Thank you
usernYyVCHEaff
Galaxy S Phones
I am having the same issue, and that did not fix it. I also have ATT.
paredman
Galaxy S Phones
I was going to disable AT&T Call Protect, but it was already disabled, so I enabled it and that fixed the problem for me. I also have AT&T. I'm not sure what to do if you force stopped it as suggested and it didn't work. Maybe try enabling it again and rebooting your phone. Hope that works for you.
userJO1mUYdzBg
Galaxy S Phones
I was able to locate app and disable it.
userv9SndjnRlJ
Galaxy S Phones
Go to play store and uninstall at&t call protector
user4XNRaOHXmU
Galaxy S Phones
I'm not showing a AT & T call protect☹🤔
