userpkZ4sp7Ymu
Phone not charging after using a wireless charger.
JUMP TO SOLUTION
My phone charged on a wireless charger overnight after the original cable was starting to fail. When I checked on my phone in the morning, my phone was not only drained of battery but any longer charging.  I tried to use my brothers Samsung s10 charger to see if perhaps the wireless charger simply didn't do its job but that wasn't the case. The phone only showed a lightning symbol and doesn't display a number nor the animation that says it's charging. I'm currently letting my phone continue to be connected to the charger to see if that would fix it.
1 SOLUTION
Neutron Star
Re: Phone not charging after using a wireless charger.
JUMP TO SOLUTION
Turn off the device, turn it back on.
When you connect the charger, pull down notification panel and look what is reports: Charging or fast charging.
You can also download app called: Ampere from Play Store and it will show you the current rate of the charge
4 REPLIES 4
JUMP TO SOLUTION
Thank you for reaching out. Have you tried wiping the cache partition on your device? Do you experience these symptoms if you try to charge your device in safe mode? What type of device are you using?
Neutron Star
JUMP TO SOLUTION
userpkZ4sp7Ymu
JUMP TO SOLUTION
This sounds very useful, however, the phone has no charge. It can't receive power at all, it disconnects and then reconnects even when using a different and newer charger.
JUMP TO SOLUTION
Thank you for that information. Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
