Crush_on_daddy
Problem with samsung health
Screenshot_20190701-002948_Samsung Health.jpgUnauthorized changes were made to your phone contact custormer service for more information(0×4000#00500065N2430
13 REPLIES 13
Samsung Care Ambassador
Re: Problem with samsung health
Have you tried installing any firmware or software on your phone other than from a authorized download
If you've found my post to be helpful, please like the post. If my response resolved your issue, please mark it as "Solved."
Note 9 User
Note 9 User on Verizon Wireless
Crush_on_daddy
No i havent . Only few apps from the web which i eventually deleted.
does it show this message on any other apps like Samsung Pay
Note 9 User
Crush_on_daddy
No it doesnt but on my secure folder when trying to set it up it shows Screenshot_20190701-010941_Secure Folder.jpg
When did the issue start happening? Do you remember the issue happening after a software change? I've seen this happen when the device is downgraded. Basically, you'll need to factory reset. I've done tons of research and testing and that's the only fix.
Best regards,
Rydah
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
usernQCYcaVEBQ
I have the same problem. Just started happening one day.  What is the fix for this?
I would recommend reaching out to our Samsung Health team directly at 855-795-0509.
Hey @Crush_on_daddy, how are you doing today?
By any chance are you rooted?
Best regards,
Rydah
Crush_on_daddy
I'm fine thanks. That im not sure of
