Gaeliol
Problems with Camera Settings Menu
I've not been able to access the camera settings menu after the last OTA Android update from T mobile for my Galaxy S8.
Does anyone hace the same problem?
Or is there a solution to this issue?.
Thanks
4 REPLIES 4
Re: Problems with Camera Settings Menu
When you go into your camera, there should be a gear symbol. This is your settings.
Gaeliol
Hi... I know where the settings icon is located. The problem is that it closes instantaneously once I touch it, therefore I don't have access to the camera settings.
A little help please🤯🤯
Try this: Go to Settings>Applications>Camera. Select Force Stop. Then select Storage and Clear Cache. Once you do this try to access the Camera settings again.
userIHsXXYRs42
Mine closes automatically after I g oil into camera settings
