user6AOr3bLjC2
S8 battery drains 1% every 1-2 minutes
JUMP TO SOLUTION
So, out of nowhere today, my S8 has started to drain battery abnormally quickly.  I've owned this phone for a little over a year and it's served me pretty well.  Sure, the battery life has gone down a bit since I first got it, now it lasts about 8 hours before it needs a charge.
But out of the blue, today it started draining around 1% every 1-2 minutes.  The screen is warm to the touch.  I know people are gonna throw in a bunch of power-saving tips in the answers (close apps you're not using, use power-saving mode, etc...) but this isn't something that seems like it's going to be fixed by a few tweaks.  I even tried power-saving mode and it continued to drain at around the same, if not faster, rate.  You can't tell me this is normal.
What should I do?
1 SOLUTION
user6AOr3bLjC2
Re: S8 battery drains 1% every 1-2 minutes
JUMP TO SOLUTION
Ok, so, after a factory reset, and a full charge, the problem seems to have gone away, and the battery life is back around 10 hours.  Though I still wish it lasted as long as it used to.  Anyway, problem solved.
9 REPLIES 9
JUMP TO SOLUTION
Does this happen when the phone is in safe mode?
user6AOr3bLjC2
JUMP TO SOLUTION
To a slightly lesser extent, but it still drains far too fast.
JUMP TO SOLUTION
Can I have your full model code, baseband version, and carrier information?
userciCWJpLxdt
JUMP TO SOLUTION
Hi,
I have the same issues after last firmware update Smiley Sad
usergZNwwOrrEV
JUMP TO SOLUTION
Is the only option a factory reset?  That seems extreme.
user6AOr3bLjC2
JUMP TO SOLUTION
userdoupyspRMQ
JUMP TO SOLUTION
Hello
Am having the same issue after the last software update. What can i provide you with and hope it solves the battery drain.
My phone used to last for 1.5 days of usage
Thank you
JUMP TO SOLUTION
Can you please provide me with your full model number and IMEI in a private message?
usertsaS1SUaAr
JUMP TO SOLUTION
I have the same problem right now every 1 to 2 minutes 1 percent drops from battery life, do i have to factory reset the phone?
