Highlighted
S8+ strange front camera issue
JUMP TO SOLUTION
color distortion bandGalaxy S8+ SM-G955FD
Strange Front camera issue
Just yesterday front camera started showing color distortion a strip horitantally for few hours then the camera stoped working at all
started showing “UNKNOWN ERROR OCCURRED”
1. Cleared Cache
2. Cleared App Data
3. Safe Mode
4. Factory Reset
5. Flashed Latest official rom via ODIN
6. Tried 3rd party app B612 and Beauty Plus
none of the above worked so I thought it must be a hardware issue I thought i will have to get the front camera replaced
today morning I tried video Call via Dailer and to my surprise Camera working perfectly for Video Call via Dailer but again Video Call not working via Whatsapp Video Call
now I am confused what is the problem hardware or software issue
Checked test code *#7353#
VT Camera (front camera) working perfectly
*#0*#
front camera not working
1 SOLUTION
Highlighted
Re: S8+ strange front camera issue
JUMP TO SOLUTION
18 REPLIES 18
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Hey man greetings, I have exact same problem with my camera. Have you found the solution maybe?
Highlighted
Honored Contributor
JUMP TO SOLUTION
Hey Community! Anyone else seeing this problem and have a workaround? Let us know!  Smiley Happy
Highlighted
JUMP TO SOLUTION
Same unkown error issue with front camera  with my samsung galaxy s8+
Highlighted
JUMP TO SOLUTION
exact same problem here. front camera 95 percent of times say unknown error, 5 percent of times front camera works for 5 seconds but it has color distortion. tried *#7353# and front camera works. what should i do? ? seems like it's a problem samsung has to fix!
Highlighted
JUMP TO SOLUTION
I am having the same problem
Highlighted
Honored Contributor
JUMP TO SOLUTION
@userZLrI6osAZ3
Be sure to try out the suggestion from VkeyAdvt. Hopefully that will help you too.
Highlighted
JUMP TO SOLUTION
Highlighted
Honored Contributor
JUMP TO SOLUTION
@user3w4ZX1xfpQ
In that case, definitely reach out to Samsung directly via Phone (1-800-SAMSUNG/1-800-726-7864) to set up a repair. Naturally you can also reach out to your carrier to see if they have a different option you might like more or maybe someone here in the Community has some other ideas!
