Highlighted
Samsung pass Doesn't Work With Rooted Phone
Hi, I have tried to root my phone but I could not.  After that when I go to use Samsung pass  then it's says that (your device has been rotate samsung pass cannot be used on rooted device for security reasons)
Is there any solution???
2 REPLIES 2
Highlighted
Re: Samsung pass
There is no solution for this as it sounds like you tripped the Knox security sensor when you attempted to root the device. The Knox sensor cannot be reset.
Highlighted
Cosmic Ray
Re: Samsung pass
Pass wont work if phone roots. Pay wont either
