user989PRUmO8a
System Volume problem with bluetooth
JUMP TO SOLUTION
I recently got a new speaker and it works great, but I cannot stop the notifications from sounding on the speaker. My notification volume is at 0 and the system volume is on max but grayed out so I cannot change it at all. I've looked online and through the settings and cant find anything on this. I have an S8+ with Android 8.0, and the speaker is iHome iX360. I have had another ihome speaker before this one and it did not do this.
1 SOLUTION
user989PRUmO8a
Re: System Volume problem with bluetooth
JUMP TO SOLUTION
I ran device maintenance and restarted my phone and the problem has been solved. Thank you for your input though.
2 REPLIES 2
Red Giant
JUMP TO SOLUTION
if you go to sounds and vibration > notification sounds > scroll up to select "silent"
user989PRUmO8a
JUMP TO SOLUTION
