Cindysgold
Cosmic Ray
multi window
JUMP TO SOLUTION
I am trying to find the mutli window settings.  I went to settings, advanced settings, there is no muli window selection.  Did samsung change it in an update?  Thank you for any help.
Cindy.
1 SOLUTION
Re: multi window
JUMP TO SOLUTION
Hey there,
Thanks for reaching out. Try giving these few steps below a try.
1. From a Home screen, tap the Recent apps icon Recent apps icon (bottom-left).
2. Scroll left or right to locate the preferred app then tap the app icon (e.g., calendar, gallery, email) located at the top of the panel.
3. Tap Open in split screen view.
4. From the Recent apps screen tap the second application to be viewed.
3 REPLIES 3
Re: multi window
JUMP TO SOLUTION
Hey there,
Cindysgold
Cosmic Ray
Re: multi window
JUMP TO SOLUTION
Thank you so much. It worked. Ive been trying to figure this out for 2 days.
Thank You!
Cindy
Re: multi window
JUMP TO SOLUTION
You're very welcome! Smiley Happy Feel free to reach out to us anytime if you need any further assistance.
