userJGCbzQfK5g
there is no option called advanced settings in my edge lighting panel s8
JUMP TO SOLUTION
after manage notifications, advanced settings missing
1 SOLUTION
Re: there is no option called advanced settings in my edge lighting panel s8
JUMP TO SOLUTION
Have you checked for updates for edge lighting in the about the menu? What version is your edge lighting on currently?
11 REPLIES 11
JUMP TO SOLUTION
userJGCbzQfK5g
JUMP TO SOLUTION
thank you i got the update today evening... i buyed it last n8 !!!
JUMP TO SOLUTION
I am so glad to hear you were able to get this issue resolved, I hope you enjoy your new device!
userdhyEfb1dB9
JUMP TO SOLUTION
It say that i have the new update but my advanced setting are still not there
Honored Contributor
JUMP TO SOLUTION
Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know!  Smiley Happy
userp6az8wp4CL
JUMP TO SOLUTION
What is the latest version?
user9f1QutQENw
JUMP TO SOLUTION
I'm unable to find the about the menu. I have no advanced settings under my edge lighting and I would like to do an update on it, if that's going to allow edge lighting for phone calls
user5dPIZxYIaN
JUMP TO SOLUTION
user5dPIZxYIaN
JUMP TO SOLUTION
