Highlighted
Honored Contributor
Re: Note 9 car bluetooth pairing issue
JUMP TO SOLUTION
J C who is your cell phone carrier? For example, do you use Verizon or AT&T etc?
Highlighted
JUMP TO SOLUTION
Sprint
Highlighted
JUMP TO SOLUTION
2016 Honda accord sport(non android auto) wont connect. Had a note 8 and had no issues. Have the unlocked note 9.
Doesnt even see the phone when I try to pair with bluetooth.
Highlighted
Honored Contributor
JUMP TO SOLUTION
Disregard, I see where you have posted in another thread as well. Smiley Happy Thanks!
Highlighted
JUMP TO SOLUTION
As you can see from this thread and others, the car bluetooth pairing problem is a systemic issue. What is the status of Samsung coming up with a solution for this? I'm prepared to return my Note 9 and go back to Apple or another competitor if this is not fixed ASAP.
Highlighted
Honored Contributor
JUMP TO SOLUTION
I'm sorry, I do not have a status or update to provide at this time. Once we have more information, we'll update the various threads publicly.
Can you guys please be sure to provide the Baseband version (Found under the About Device section in settings) and carrier information as well? Even with the unlocked versions we need this information. Thanks!
Highlighted
JUMP TO SOLUTION
Baseband version: N960USQS1ARI5
Carrier: ATT
Highlighted
JUMP TO SOLUTION
2016 Honda Accord Sport (non Android-auto)
Unlocked
SM-N960U1
Verizon
(Does not recognize the note 9 but works fine with note 8)
Highlighted
JUMP TO SOLUTION
Baseband Version: SM-N960F/DS
Carrier: starhub
Model of Radio:
Make/Model of Car: Renault Kajar
Highlighted
JUMP TO SOLUTION
I also am having the same issue with my 2018 Toyata Camry with bluetooth disconnecting every few minutes and reconnecting.
Are there any updates on this? Since apple car play now offers ways i will check if there is a resolution in the next week. If not back over to apple.
Note 9
Team Mobile
