userBhznDqsQ8d
Wireless Duo Charger blinking red lights and not charging after plugged in
JUMP TO SOLUTION
I was wondering why does the duo stand keeps flashing red lights and not charging my devices. I plug in and it shows green, orange and lastly red lights that appear to start blinking 2 secs. after. I'm using original wall charger included with S9+.
1 SOLUTION
Re: Wireless Duo Charger blinking red lights and not charging after plugged in
JUMP TO SOLUTION
Just give this number a call and they will have the part numbers for you:  1-800-627-4368
15 REPLIES 15
JUMP TO SOLUTION
Thank you so much for reaching out to us for assistance, We would be happy to look into this further for you.
Can you confirm some information for us?
What is the model code of your duo charger you are using?
Are you using the charger that came with your S9+ or the one that came with the Duo which is bigger in size and looks similar?
userBhznDqsQ8d
JUMP TO SOLUTION
Hi, it is the EP-N6100 model. I'm using the OEM wall charger that came included with the S9+ box.
JUMP TO SOLUTION
We would recommend using the charging cable and block that came with the Duo Charger.
user1UaVoiJk2S
JUMP TO SOLUTION
Where can i get a replacement cord and charger block that works for it
JUMP TO SOLUTION
You should be able to find a replacement cable and block on samsungparts.com or samsung.com
usernatW7g0OMD
JUMP TO SOLUTION
Is there a part number for those?
userVWUHRKEedg
JUMP TO SOLUTION
JUMP TO SOLUTION
userzx2h2XVAck
JUMP TO SOLUTION
Hi I have the original charger and cord and it is still blinking red and does not work. What should I do?
