Highlighted
Samsung duo charger missing charging block
Hello, I recently bought a Samsung duo wireless charger without a charging block. Does anyone know where I can find the OEM block or an alternative? I've tried using high voltage chargers such as a 25v 2 amp one from Amazon and they just don't seem to work. Thank you!
1 REPLY 1
Highlighted
Re: Samsung duo charger missing charging block
Hello!
Thank you for reaching out, I can understand wanting to get a block so you can use your duo charger. I would recommend contacting Samsung parts by calling 1-800-627-4368 and inquiring about the charging block you would need.
