- Mute
05-07-2022 05:44 PM in
Galaxy Z FlipSolved! Go to Solution.
- Mute
06-01-2022 09:35 AM (Last edited 06-01-2022 09:35 AM ) in
Galaxy Z FlipHello, I know how frustrating battery drain is. Some things that can help with Battery optimization, if you're just having a battery draining issue, is the following:
Optimize Apps:http://www.samsung.com/us/support/troubleshooting/TSG01001388/
Power Saving Mode & Battery Tips: https://www.samsung.com/us/support/answer/ANS00079037/
If you're receiving an overheating message check out the following link: https://www.samsung.com/us/support/answer/ANS00079037/
If you've tried troubleshooting above, when it comes to problems overheating or exorbitant drain to the battery, repairs would be recommended. This would be covered under the warranty. You may look into walk-in service repair options at your local authorized service center: https://www.samsung.com/us/support/service/
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
Samsung also offers ship-in repair options. Typically if the local repair center cannot fix an issue, the next step would be the ship-in repair. To look into ship-in options, you can private message us here with the full model code and IMEI number: https://bit.ly/3pE8Pkc
- Mute
05-07-2022 07:03 PM in
Galaxy Z Flip- Mark as New
- Mute
05-08-2022 07:12 AM in
- Mute
05-14-2022 08:16 AM in
- Mute
05-24-2022
10:15 AM
(Last edited
05-25-2022
01:15 PM
by
SamsungRyder
) in
Hey guys, I have had the Galaxy Flip 3 phone for a while and understand that the battery drains VERY quickly and wanted to if my experience is the exception or the rule.
I usually charge my phone at night to 100% and in the morning, let's say 10 hours later, the battery is down to 85% meaning that it drained (degraded) about 15% in 10 hours while it was not in use.
I checked with Samsung support and they said that this is normal and wanted to check with other end users, if it is in fact, normal?
Thanks guys
Bob
- Mute
05-24-2022 11:39 AM in
- Mute
05-24-2022 12:15 PM in
Galaxy Z FlipMy brother had one for a little bit and it drained about that much over night
- Mute
05-24-2022 12:21 PM in
Galaxy Z FlipThanks guys, I believe that the Flip 3 has 2 batteries, one for when it is folded and another in the normal (upright) position so there is not much real estate for larger batteries.
Anyway, it is what it is and I definitely like the convenience of being able to fold the phone.
- Mute
