battery issue
JUMP TO SOLUTION
My galaxy zflip battery is draining too fast at the end of the day i have to charge it everytime and my screen on time it has been 3 hours or sometimes less does anyone has some tips ?  I keep my Bluetooth and wifi off when i don't need it and im new to android and Samsung phones is there anything that i might be doing wrong?
1 SOLUTION
Re: battery issue
JUMP TO SOLUTION
Have you tried to optimize your battery on the device?
https://www.samsung.com/us/support/troubleshooting/TSG01001388/
You can also take a look at this other link to get the most out of your Samsung device:
https://www.samsung.com/us/support/answer/ANS00078987/
I hope this helps!
1 REPLY 1
Re: battery issue
JUMP TO SOLUTION
I hope this helps!
