Gear 360 (2017) won't charge/turn on
(Topic created: 08-03-2017 09:51 AM)
user04tBTyvEs2
Gear and Gear Fit
My new Gear 360 arrived yesterday. I installed a memory card, then plugged the camera in with the included USB cable and my Samsung charger. The manual said to let it fully charge, so I left it plugged in overnight. This morning I tried to power up the device, but there is no response whatsoever. No lights, no display, nothing. I know the charger is good because it charges my S7 just fine. The manual isn't very detailed, so I'm not sure what to do. Any suggestions?
JUMP TO SOLUTION
userUXyBqBDeHw
Gear and Gear Fit
I did the plug into the computer usb port idea.
It worked. Light came on, unplugged it, unplugged it in the wall, it's charging now.
useri8tAgtS3aY
Gear and Gear Fit
Thank you!! It worked!
useri8tAgtS3aY
Gear and Gear Fit
Thank you
useraolwrt4Car
Gear and Gear Fit
This worked for me too. I don't know what makes it "wake-up" but it is working right now
userYg41GuCdu6
Gear and Gear Fit
Plug it into a power bank first.
userU8Sj1yTjiH
Gear and Gear Fit
Plugged mine into a power bank and it worked!
user27UXce5p5M
Gear and Gear Fit
tried wall, computer then a little portable battery charger which finally worked
userN12yfB5ijb
Gear and Gear Fit
thanks this worked for me !
user13jAyVmhTK
Gear and Gear Fit
Thanks so much! Worked for me!
Morrivar
Gear and Gear Fit
@userXDhColqWZ2 wrote:
Here is what worked for us.
1. Plug the camera into a compter USB port with the supplied USB-C cable
2. Wait for the charging indicator light to illuminate above the power button.
3. Disconnect the camera charging cable from the computer's USB port.
4. Plug the camera's charging cable into a wall charger of your coice.
This has worked for every camera we have come accross, including the 2 we recieved for my kids's phones.
Hope this helps.
-dphillipsjr76
This worked beautifully for me.
