Gear 360 (2017) won't charge/turn on
(Topic created: 08-03-2017 09:51 AM)
user04tBTyvEs2
Gear and Gear Fit
My new Gear 360 arrived yesterday. I installed a memory card, then plugged the camera in with the included USB cable and my Samsung charger. The manual said to let it fully charge, so I left it plugged in overnight. This morning I tried to power up the device, but there is no response whatsoever. No lights, no display, nothing. I know the charger is good because it charges my S7 just fine. The manual isn't very detailed, so I'm not sure what to do. Any suggestions?
JUMP TO SOLUTION
user8qiyR8Y5kh
Gear and Gear Fit
It worked for me ! Thank You !
userSl4Y5ob9hN
Gear and Gear Fit
Thanks, problem solved!
useryeMvysV2k4
Gear and Gear Fit
Update I was expecting a quick reply via samsung with an email so I can return my faulty cam for a new one.   I contacted customer support through promotions and was told today it would take up to 48hr meaning at least 6 days before I got a reply..........NOT happy with Samsung Customer Service.  I was excited to get the new 360 cam and try it out but if the Cams have issues then whats in store for all us new Note 8 users.????????????
@usersJqunbvV3l wrote:
Hi dear !
I have the same prblm with the new Samsung gear 360….The solution it so easy, just use a power bank to charging the Gear & it going to back in life…
Good luck bud Smiley Happy
userIa9Z4itoRA
Gear and Gear Fit
i did the same, and it worked thaks mate,
useru8UkYmIoCR
Gear and Gear Fit
Hello to all the community
I would like to know how to charge the gear 360
I was able to use it and charge it, but now after some while of no usage it doesnt start or recognises the power not even a red light
SamsungKim1
Supernova
Gear and Gear Fit
You cannot charge the Samsung Gear 360(2017) while recording a video, using the time lapse feature, or using the viewfinder remotely on the connected mobile device. This is intentional to write better images/videos and maintain system stability.
If the Auto turn off function is disabled, charging is disabled to prevent overheating and damage. While charging, the Samsung Gear 360(2017) and the charger may heat up. This is normal and should not affect the Samsung Gear 360's lifespan or performance.
If the battery temperature rises above a certain level, battery charging will be stopped. Using a power source other than the charger, such as a computer, may result in a slower charging speed due to a lower electric current. And, please use only Samsung-approved chargers, batteries, and cables.
user6aHX9UM8EE
Gear and Gear Fit
Same problem
userJ8GI8SlZyu
Gear and Gear Fit
I also have same problem. Not able to reach out to customer service.
user0sRcHb7L5T
Gear and Gear Fit
Make sure memory card is empty.
userLtsbdyIBYe
Gear and Gear Fit
This happened to me last night and I rebooted my tablet and the charge indicators came right on and started charging.
